Checked it before I started it, oil level was way high. Checked it about 5 times. Let it run and heat up, checked it again and it was at the same spot.
Doesn't seem like the oil is getting trapped in the valve covers then. Pull a plug and check it's condition, does it look oil soaked? If several random plugs are oil soaked with the oil level at normal more than likely worn oil rings then. Galaxy S4 Cetane Powered Android
Sounding like the better option. At least 302 parts are cheap and plentiful and it's not your every day driver Sent from my SAMSUNG-SM-G870A using Tapatalk
I think I'm done chasing this problem. Getting an engine hoist from one buddy and a stand from another. I think I've got a set of heads picked out already, need to find a GT40 upper and lower intake. Looks like they came on the explorers. Gotta pick out cams and pistons. Not getting this done anytime soon.
://m.summitracing.com/parts/fms-m-6049-x306?seid=srese1 Need to find a good balanced cam. ://m.summitracing.com/parts/pro-302-003 Need these too
As some of you guys may know, this project has been put on hold. My brother blew a rod bearing in his Jeep engine so I'm rebuilding that. Hoping I'll have it done by the end of the month.
Starting the project up again. Pulled a set of GT40p heads from a 97 explorer today. Cost me $75. Building an engine for the truck, either a 302 or a 351. I have a friend that has a friend with a 351 block laying around, might be taking it off his hands. Updates will come while I progress.
