Reliable AMP Research power running boards for Ford on SALE at CARiD
Discussion in 'CARiD.com' started by carid, Sep 13, 2017.
    Make the climbing into your pickup's cab more convenient and ease up the access to your roof and bed with a set of electric-powered running boards by AMP Research. Being a leading provider of automatic power articulating running boards, AMP Research created a complete line of boards developed to maximize your comfort and provide you with the best support possible when you need it. Engineered not only to be a perfect fit for your Ford, AMP Research PowerSteps are equipped with special slip resistant pads, that won't let you down, no matter the weather.
    Purchase any set of AMP Research PowerStep, PowerStep XL or PowerStep XTreme running boards and get up to $150 back!
    This offer is valid till September 30, 2017.
    Provide your truck with a clean look and get the easiest access to the cab with AMP Research automatic power Running Boards!
    Make sure to complete the PDF form below to redeem your Visa Card.
    https://www.carid.com/images/amp-research/info/amp-rebate-form.pdf
