1995 f350 no start
Discussion in 'F-250 and F-350 General Tech and Info' started by EricG0711, Aug 11, 2015.
  1. EricG0711
    EricG0711 Junior Member
    US
    Hey guys I have 95 f350 running a 351w that will not start. Doesn't seem to be getting fuel. Can spray gas in the breather and will start. All new parts including headers and ecm. Any advice is appreciated.
    Sent from my SM-T530NU using Tapatalk
  2. thesman727
    thesman727 Full Access Member
    US
    Does it stay running once you spray it?
    Insert tab A into slot B and........pound it with a hammer!
  3. Roush PSD Interceptor
    New fuel pump, fuel filter?
    Are you getting fuel pressure to the injectors/carb?
  4. EricG0711
    US
    No it does not stay running afterward and all new fuel tank, filter, and lines. Not sure about fuel pressure to the injectors
  5. Roush PSD Interceptor
    Should be a Schrader valve on the fuel rail to purge off air on first time
    Start up. Get someone to crank while you depress Schrader till fuel comes out. If no fuel check for voltage to fuel pump proper pump operation.
    If pump is working but no fuel to fuel rail Recheck fuel line connections making sure of good fitting connections from tank to fuel rail.
  6. gruesomesurfer
    gruesomesurfer Full Access Member
    Las Vegas, Nevada
    They are right. It seems like that the fuel pump is the cause of the problem.
  7. AnyThingAuto
    AnyThingAuto Junior Member
    US
    Check the fuel pump emergency shut off, located on you fire wall. And fuses 1st
    Sent from my XT1635-01 using Tapatalk
