I fixed this car's Window Regulator Assembly about year and a half ago (RockAuto). I replaced the broken door panel with a used one where their family broke it trying to remove it from the door. Now it's back, window no go up or down. Screws behind door pull handle. There is no screw in the rear near door latch. Front spring clip is missing on the switch panel. One screw behind panel. BTW the door panel lifts straight up when the screws are removed, then tilt forward to clear door open latch handle. Three screws hold motor and regulator to motor bracket. Look what I found after removing the motor gear cover, brittle gear plugs. Be sure to get all the bits out. New gear plugs. Mystic grease on the motor pinion shaft. Done. Window go up, window go down.
