1999 F-250 4x4 5.4 Noise Timing Chain?
Discussion in 'Engine & Performance' started by hardbound, Sep 21, 2015.
  1. hardbound
    hardbound Junior Member
    prince george,va.
    After replacing plugs and coil packs noticed noise coming from front of motor timing chain area pretty sure . New to me truck with 171,000 on clock. Do you guys think it's worth pulling down and replacing timing chain and guides with that my miles or a motor rebuild? Motor seems strong and runs good after plugs and coils.
  2. iowaredneck
    Just replace the timing chain
  3. Roush PSD Interceptor
    For peace of mind,
    to bad you didn't do a
    compression test while the plugs were out,
    and a cylinder leak down test.
    Wouldn't hurt to replace the timing set and guides.
    Are you getting any blow-by with the oil fill cap off?
  4. MyFX4Project
    MyFX4Project TRUCKIT
    Kansas
    Sure it wouldn't hurt to replace the chains and guides, but more importantly replace the tensioners because that's what gives out and allows slack in the chains.
  5. hardbound
    prince george,va.
    Have not noticed any blow by. Do the tensioners come with kits that have timing chains and guides? Found out that tensioners come with kit I'm going to order . I have another question someone had made problem could be cam followers can't seem to find that part listed anywhere?
  6. Roush PSD Interceptor
    Thomas just went through his 5.4 rebuild recently.
    He or another member more familiar with that engine and its parts can answer that question when they read your latest post.
  7. hardbound
    prince george,va.
    thanks bud
