4wd Conversion
Discussion in 'Lifted' started by 03f150-06CBR100rr, Apr 20, 2012.
  1. 03f150-06CBR100rr
    03f150-06CBR100rr Junior Member
    Spring,Tx
    Has anyone done a 4wd conversion on a 2003 F150 supercrew? I was thinking about doing dana 60s and the t case with manual shift. Reason I wanted to do dana 60s is becuase later on I might to a diesel conversion. I know it's always cheaper to go buy what I want but, I like the idea of standing out in a crowd. Parts list (dana 60 front & rear differential, front drive shaft, t case) should the rear be posi traced?
  2. AKBray907
    sounds like you want to do a SAS( solid axle swap) google that and youll get loads of stuff about doing it!
  3. VanoFord
    I'm on the fence of converting to 4wd or just trading up as well. I want a diesel too, but I know I dont want to do a diesel AND 4wd swap. my biggest issue is runnin all the vac lines since my truck is already wired for 4wd-on-the-fly
  4. cowboy
    it would be a fun project.
  5. TxFx04
    Lets just say it's easier said then done. It requires a LOT of custom fab. and alot of the green stuff too
  6. AKBray907
    an he ain't talking bout no weed
  7. 01f1502wd
    yup, axles, t-case, shafts, coilovers, 4link and panhard bar i think, steering stuff... straps and bumpstops and your done.
  8. TxFx04
    or you can go the cheap route and throw leaf spings under it
  9. SolidF150
    SolidF150 Full Access Member
    SAS, you will never regret it. Don't let the money turn you away from it.
  10. TxFx04
    Do it right like this guy^^
