6.9 idi questions
Discussion in 'Engine & Performance' started by thesman727, Aug 5, 2015.
  1. thesman727
    thesman727 Full Access Member
    US
    My friend is looking at buying a 1988 (?) F250 with the 6.9 diesel. It gets air in the fuel lines. Is this a common problem? Is it serious? Is it expensive? Are there any other serious problems with this engine?
    Insert tab A into slot B and........pound it with a hammer!
  2. FofTworide
    FofTworide Full Access Member
    GA
    You may want to check the fuel return lines for crack.
  3. thesman727
    US
    How serious is this issue?
  4. Bdons-SD
    Fuel lines are a pretty easy fix in general. I don't know enough about the 6.9 to diagnose though. If it were me I would start at the fuel rails and work my way back.
