'94 302 Overheating Problem
Discussion in 'Engine & Performance' started by burchmane, Oct 30, 2014.
  1. burchmane
    burchmane Junior Member
    I have a 94 F-150 with a 5.0 and I'm having an overheating problem. I was driving along and looked behind me to see enough smoke to blind the cars behind me. So I tried changing the thermostat and flushing the radiator. It seemed fine a few days, then the problem occurred again. Only this time my bottom radiator hose busted. I got that changed thinking it may have been old and closed in on itself. Once again it drove fine a few days and now the same problem. Any ideas?
  2. iowaredneck
    Check your head gasket if its blowing smoke
  3. Roush PSD Interceptor
    Maybe leaking only after several days.
    Pull and number
    the spark plugs, look for ones
    that seem to be steam cleaned.
    At least that will narrow it down to which side is leaking
    or hopefully not a cracked head or block.
