Bambi Mod
Discussion in 'Interior' started by ak_cowboy, Jan 28, 2011.
  1. ak_cowboy
    Here are a couple (lame) pictures showing how to do the Bambi Mod. Having fog lights on with high beams :peace:
    Fuse Box with Brown Jumper Wire grounded.
    Relay that the wire is grounding out.
  2. Shaggy
    Arizona
    Any chance of fuses blowing with that setup?
  3. rrogers
    not at all this mod is excellent if you want to run your brights and fogs at the same time
  4. cowboy
    probably should be moved to tech write ups. Nice one Will I got this in my truck as well for the longest time no problems yet.
  5. DarkShadowSTX
    DarkShadowSTX the "brat"
    Brecksville, OH
    Does this bambi mod just allow you to run fogs and hi beams at the same time? Reason is I have a retrofit projector kit and when I turn my fogs on, the hi beams come on at the same time already. Not trying to hijack the thread, but how can I fix that so my my lights work normally or fogs and hi beams?
  6. cowboy
    yes it does, not sure how to fix your issue sounds more like a crossed wire that is energizing your bright's when you flip the fogs on.
  7. DarkShadowSTX
    Brecksville, OH
    I don't know how anything can be crossed. There were lots of wires for these lights but all had connectors that only went together one way, you know. And I know my battery connections aren't messed up. lol
  8. Nitewolf
    Nitewolf The Big Bad Wolf
    Clarksville, TN
    Is this just another way of how I did mine?
  9. cowboy
    your only like an hour drive from me. Maybe one weekend coming up I can make a trip down there and give you a hand on figuring it out.
  10. cowboy
    yes Mike it is. So much easier to get in the fuse box and pull a relay ground one of the prongs and put it back in.
