I got a 99 f150 extended cab 4x4 with a 4.6. The brake line running along the frame on the driver side to the soft hose above the rear end busted right where it runs between the frame and the fuel tank. Anybody that's fixed this have any advice? Parts list? Have a very limited amount of time to do this so I gotta try to gather everything I need before I start.
I would check RockAuto. I had to order mine from Ford, but your's should be available through them. 4x4 or 2wd?
I had it happen, same place too. Went to the parts store, picked up a piece of line long enough, ripped the old one out and replaced it. Shouldnt take more than a few hours at best.
Gave the fittings a quick blast of pb blaster last night. Going to knock it out this afternoon I hope. As long as I can get off work in time.
