davbell22602: 67 F100
Discussion in 'Under Construction' started by davbell22602, Aug 9, 2013.
  1. davbell22602
    Bunker Hill, WV
    Ok, Here's build thread for 67 F100. Gonna pay a mobile welder to repair the rotted holes on frame where the core support and front cab mounts go. Then paint its on to painting the frame with the purple power deruster, gray primer, and black paint.
    I already checked the cab support mounts and they dont look to rotting out the holes yet.
    Here's pics
  2. 97madness
    Cant say for sure, but I would have to guess there is some form of rotting going on. If you have it down to that point, you may aswell go all the way, since you're committed. Do it right first, and there wont be a second.
  3. BlackThundah
    You should get a welder and learn on your truck build. Maybe not the frame points since there critical to the whole truck, but it would be a fun way to learn on smaller stuff.
  4. Pity7700
    surprised joe didn't already say this
    POR-15 that biotch!
  5. Roush PSD Interceptor
    Yep but I was thinking it though.
  6. davbell22602
    Bunker Hill, WV
    I got a Lincoln/Century GL80 wire feed for going the sheet metal on the cab and bed floor. Last time I welded was in HS and just did arc welding.
  7. iowaredneck
    Well good luck lots of fun work ahead
    sent from area 51
  8. davbell22602
    Bunker Hill, WV
    Thinking about using rustoleum after using the purple power deruster.
  9. davbell22602
    Bunker Hill, WV
    Welder quoted me $120 to repair the 4 holes at my house.
    Picked up this radiator support for $75 out of a 75 truck. Not a direct fit will fit with tweaking.
    Sent from my XT881 using Tapatalk 2
  10. forduke
    forduke Member
    Fl
    Looks like a cool project. Will definitely follow this build thread. Good luck man!
