Engine surge
Discussion in 'Engine & Performance' started by mazak5962, Jun 22, 2016.
  1. mazak5962
    mazak5962 Junior Member
    Winchester, Tennessee
    I have a 1999 f-150 4.6L. Just recently started having idle surging as well as while it's in gear. Any ideas what might be causing this? Thanks
    Sent from my SM-G920V using Tapatalk
  2. Bdons-SD
    I'd start with your idle air control valve. Should be somewhere on your intake or throttle body. Get some idle air control valve cleaner and clean it, it should help, or for like $70 you can replace it.
  3. gruesomesurfer
    gruesomesurfer Full Access Member
    Las Vegas, Nevada
    Have you also had the torque converter checked?
