Front bench swap
Discussion in 'F-250 and F-350 Interior and Exterior' started by cryoguy6075, May 27, 2013.
  1. cryoguy6075
    cryoguy6075 Junior Member
    Yuma
    Hey all... I have a 93 F250 single cab with a bench seat. I would like to swap in some buckets from a similar year truck. Does anyone know which seats will fit, and if i cant find the right one are there other options? Thanks!
    Sent from my SPH-M830
  2. iowaredneck
    Pretty sure they will fit
    sent from area 51
  3. cryoguy6075
    Yuma
    The only trucks that had buckets were the extended cab. There aren't very many of those around here. Are there any other options that are close to bolt on?
    Sent from my SPH-M830 using Tapatalk 2
  4. TLSF150
    TLSF150 Full Access Member
    Stockbridge, Ga
    Bronco seats should be a direct bolt in
  5. cryoguy6075
    Yuma
    Sweet... I just need to find a junkyard with some broncos... Thanks!
  6. TLSF150
    Stockbridge, Ga
    Well I say direct bolt in but you may or may not have to drill a few holes.. but they will work.. Id bet the holes are already there though
  7. cowboy
    cowboy Sheriff Staff Member
    try bronco graveyard or rock auto. They may have the seats although shipping might be a bit pricey
