Alright guys I can't locate this problem, when I hit the brake I hear a click coming from the fuse box in the passenger side footwell. I thought this was related some how to my doing the "Bambi mod" but I took the Bambi mod off and it still clicks. Go figure. I also have a problem where my blinkers won't come on and make an annoying buzzing sound (as If I have no bulb in) when I have my headlights on. When the headlights are off the blinkers work fine. Now they do the hyper flash normally, but that's because I have led bulbs In my blinkers. And I just haven't gotten around to buying resistors to make them flash normally. I don't know if it would help but I have HID's in my fogs and headlights. I hope y'all have a better idea as to what's the problem than I do. Thanks for the help Sent from my iPhone using Tapatalk
ok as far as the blinkers, you can either get the resistors and splice and dice and have it like that, but if you don't want to splice and dice the wires you can get the led flasher and replace it with the original flasher. now the flasher is ep-27L, L meaning its for led lights and that just goes were the original flasher goes
Okay but would that explain the clicking I hear when I hit my brake pedal? And the error the blinkers have only when my headlights are on? Sent from my iPhone using Tapatalk
That is strange. It might be the combo of LEDs and HIDs interfering somehow. I would replace the Flasher relay first and see if that helps.
agree with Will. Or if you still have the old bulb's throw them in there just to see if the clicking goes away.
