i didn't take enough pics to do a how to, the headliner is pretty simple, remove all the trim pieces to take it down, remover old material leaving the old foam, spray glue on foam, let it get tacky then lay the material down and smooth it out for the door panels, remove the door panel, for the speaker grills i sanded them real quick, taped them off and sprayed 'em with a black enamel, the bottom, just peel the carpet off, used an adhesive remover to get "most" of the old glue off, then i put some backing on and sprayed it with glue and just worked the material to get it smooth and used a razor blade to trim the excess material
