Heater problem
Discussion in 'Interior' started by josh0206, Dec 26, 2013.
  1. josh0206
    josh0206 Junior Member
    I have a 2007 f-150 lariat and my heater is not blowing warm air. It blows air but does not get hot. Also, i've checked the coolant and it is good. Any suggestions?
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  2. Pity7700
    does it work when you turn on the defrost?
  3. Roush PSD Interceptor
  4. Pity7700
  5. Roush PSD Interceptor
    Muh hands are way to big to be stuffing
    inside the dash to work on actuators.
  6. josh0206
    No doesnt work on defrost either
  7. josh0206
    And thanks whenever I get back from work Wednesday I'll try to find and check the voltages
  8. Pity7700
    when I put a new heater core in it was recommended that I replace the blend door while I had the dash all torn apart and since the job takes so long. of course I said hell with it and didn't bother with the blend door :jester:
    im sure thatll come back and bite me in the ass.
    if you find out its the bled door you might consider replacing the heater core while youre back there. $40 for the heater core and like $20 for the blend door. theyre both in the same housing.
  9. iowaredneck
    I assume your truck is heating up properly? Gage reads like it should?
    If so then im too guessing blend door
