Help truck won't turn over
Discussion in 'General Discussions' started by Johnny5101, Mar 14, 2016.
  1. Johnny5101
    Johnny5101 Member
    Ohio city, ohio
    Ok, so I am having the worst luck ever!! I got the other motor in the truck. And it ran awesome for about a week now. No issues and no noise. I put an edge revolution cts programmer in it as of now. I had it on level 2. I pulled a trailer 2 hours one way. Ran great. Woke up this morning. Went outside and strarted the truck. Fired normal. Went inside for two minutes. Came outside to leave and the truck wasn't running. So I went to restart the truck, and now it won't turn over. There is no crank whatsoever. I checked the fuses and tapped on the starter. And nothing. Can ANYONE give me any advice? I'm stranded as of now 2 hours from home!! Thanks so so much!! Also. My battery is fine. Gas gauge and battery gauge works
    Can you set it back to stock and try to start?
  3. iowaredneck
    Set it back to stick unplug the battery for a bit and try again
  4. Johnny5101
    Johnny5101 Member
    Ohio city, ohio
    The gauges on the programmer do not appear. Just 3 dots in each box. And there I had it in level 2 for towing. It now says level 0
  5. Johnny5101
    Johnny5101 Member
    Ohio city, ohio
    I called edge technical support and they were absolutely no help. And that's after I was on hold for 15 minutes!
  6. Roush PSD Interceptor
    Never think you would need to carry a back up programmer with you
    to load stock tune back to the ECU.
  7. ak_cowboy
    Unplug the programmer, unhook the battery, wait 5 minutes. Hook only the battery up and try it.
  8. Johnny5101
    Johnny5101 Member
    Ohio city, ohio
    Tried all that. But thanks for the attempts. I took it to my ford dealer. The on (computer) is no longer! They are telling my the the edge programmer fried my computer. I'm not sure how. But through all their tests, they came up with that diagnosis. And then they wanted $1300 for a new ford oem computer! I told them I could get a new one that comes programmed to my vin# as well as 2 new keys programmed for $239.99. They weren't happy with that answer. So now I'm waiting to get the new computer. Won't be here for about 7-10 days. I'll let you know if that fixes it. Just frustrated. I got the programmer to help me watch things better so I wouldn't have to put more money into this darn truck!!
  9. Roush PSD Interceptor
    Way to shoot down their service bill.
    Bet they thought you would only let them fix it for that unreal $1300 amount.
    Best of luck getting it back to running again.
  10. iowaredneck
    Bummer man. Hope new computer helps
