How easy is it to remove/reduce a significant lift?
Discussion in 'General Discussions' started by M116Fullbore, Nov 1, 2016.
  1. dchawk81
    dchawk81 Full Access Member
    Good call. Find a truck that's closer to what you actually want instead.
    I've found my 235/70/15 on the Ranger XLT parts getter cost more than the same size
    16 inch tires in several different brands.
    So look for one that already has 16's on it.
  3. M116Fullbore
    M116Fullbore Junior Member
    delete
    Huh, most of the ones I am looking at end up being about 80-100 bucks more expensive per tire when you keep roughly the same dimensions but go to a 16" rim instead of a 15.
    I dont mind eventually getting other rims, but having to do so immediately due to bald tires and no availability was definitaly not something I was interested in. That plus removing half the lift was a bit much to do right off the hop.
    Currently looking at a blue f150 1995 extended cab shortbox with 240km on a 302 5 speed for a thousand bucks less, old retired guy's disability cant use the manual anymore. Might be a better place to start.
  4. M116Fullbore
    delete
    Bought it! see if i can post pics soon.
