How To: Change Brake Pads
Discussion in 'Tech Info' started by ak_cowboy, Feb 7, 2013.
  1. ak_cowboy
    I had to change out my front brake pads and took some pictures!
    You'll need:
    13/16" Socket for taking off the wheel
    18mm for taking off the brake caliper
    13mm for relaxing the brake pads.
    Take off the wheel after turning it in, support with jackstands.
    Backside of Caliper
    Caliper Removed. Take off the two rearmost 18mm bolts. Then use a long screwdriver or prybar to pull the caliper off
    Support the caliper! DO NOT let it hang by the brake line
    Pull the old brake pads out.
    Use a C-Clamp to compress the pads. Your new pads will be thicker than the old ones and won't fit otherwise.
    Old pads vs New Pads
    Brake pad Spring. Don't Lose These. They keep the brake pads spread and off the rotor
    Springs installed
    Installation is the reverse of taking it apart. Make sure to pump the brakes to set the pads, top off brake fluid if needed, and follow proper brake break-in procedure. :waytogo:
  3. iowaredneck
    nice write up. i would say your pads were shot.
  4. Pity7700
    hahaha shiiii, them pads were gone!
  5. Roush PSD Interceptor
    Def no hanging calipers by the hose.
    yeap purty much used them pads all up.
  6. ak_cowboy
    Haha I had about 85k on those pads and blew out the passenger caliper. The brakes are a little softer than I like, but I'll get them bled out eventually and fix that.
  7. TxFx04
    nice write up man :peace: luckily when we did my lift the brake pads still had about half life yet
  8. ak_cowboy
    Thanks. Forgot to mention that the rotors come right off if you're going to swap them out too. No other tools needed.
  9. cowboy
    Good work
  10. AKBray907
    No way your rotors weren't toast
