How To change o2 sensors (downstream) PIC HEAVY!!!
Discussion in 'Tech Info' started by VanoFord, Mar 15, 2012.
  1. VanoFord
    So I swapped out the rear (downstream) o2 sensors on my truck yesterday. prolly will swap out the upstream in a few weeks, just to be new all over. as usual, i ordered my parts from Rockauto. I went w/ Motorcraft parts (they werent that much more than generics). I was pleased to see that they were shipped w/ anti-sieze already on the threads. the electrical connections are color coded so you can't put an upstream module into a downstream port. Purple is down stream. Grey is upstream. All I used was a crescent wrench. Make sure to disconnect your battery when swapping these out. Took me 20 min to swap both of these out. And onto the pics:
    Here are the plugs, w/ the driver side already removed.
    Driver side downstream o2 location:
    driver side downstream o2 electrical connection:
    driver upstream o2 sensor:
    passenger downstream o2 electrical connection:
    passenger downstream o2 sensor:
  2. iowaredneck
    :waytogo: nice write up thank you
  3. BlackThundah
    Yah nice write up man. Im not to shure my truck has 02 censors. :hmm:
  4. TxFx04
    it should have them lol 4 of them
  5. thegreatscott
    thegreatscott Junior Member
    massachusetts
    This is a great post mate, i also have this universal car oxygen sensors that i just recently bought and it has a manual. I wonder if this is compatible with my truck. They said that it is compatible when i asked them when im buying it.
