how to headlight paint
Discussion in 'Exterior' started by jlyoung08, Jun 16, 2011.
  1. jlyoung08
    Supplies:
    Kitchen oven
    masking tape
    sharp straight edge razor
    Torx T-10 screw driver
    needle nose pliers
    flat-head screw drivers
    400 grit sandpaper
    Plastic paint
    Automotive grade silicone sealant
    piece of cardboard
    Step 1: Remove your headlights from your truck and remove the bulbs. You may also want to give your headlight a good wipe down with a wet cloth so you don't get any dirt or mud in your kitchen oven.
    S2: Preheat your oven to 250 degrees F. Turn off your oven. Place a piece of cardboard between the oven shelf and the headlight. Let the headlight sit for 10 minutes. (DO NOT EXCEED 10 MINUTES, you will melt your headlight). For the geniuses...bake one headlight and pry it open and bake the other don't try two at a time.
    S3: After baking for 10 minutes, take a screwdriver and pry the headlight apart (your headlight will get slightly deformed around the edges of the black plastic). Use the screw driver to pry half apart then use your hands to pull the rest apart. You may have to put the headlights back into the oven several times (BE SURE TO REMOVE THE CARDBOARD EACH TIME YOU RE-HEAT THE OVEN.)
    I found this corner to be the easiest side to start on.
    S4: Use your torx screw driver and remove the reflector part of the headlight from the clear lens. The two screws are located here.
    S5: Do NOT get any finger prints on the chrome reflector or orange reflector it will show up when you paint the parts. Remove the orange reflector from the larger chrome piece. Using 400 grit sand paper, sand the chrome off the larger piece shown below. Use some masking tape and tape off the smaller turn signal/parking light housing. I used a very sharp straight edge razor to get a good circular cut.
    S6: After sanding use some paint thinner to clean the large reflector piece and the orange reflector (if you plan on painting the reflector too). You can use what ever kind of paint you want as long as it's made for plastics. I used Krylon black glossy plastic paint for the large piece and VHT Niteshades for the orange reflector. Paint the pieces in a low humid area and also out of the wind. I used very very light coats of paint on the larger pieces until the whole can was used. Then on the orange reflector I painted the reflector with the niteshades to the darkness I liked (If you paint it too dark on the first time don't worry). After about 2 hours the orange reflector will be dry, take it and sand it with 400 grit sand paper until all the paint is gone and leave the edges of the orange reflector black. Repaint the reflectors to your liking. (I did not paint mine too dark because of the law here states that your reflector has to be seen from at least 30 feet, the reason for painting and sanding is so your edges of your reflector will be good and black so they will blend in easy, if you don't do this step the edges will tend to be brighter orange than the rest of the piece.)
    S7: Let the pieces dry for at least 5 hours. Clean the clear lens very good inside and out you don't want any finger prints inside the light after it's all sealed up again. Then put the orange reflector back into the larger piece and screw the assembly back onto the clear lens.
    Make sure there is nothing inside your oven and preheat it to 250 degrees F. One at a time, place the back part of the headlight (shown below) into the oven again for 10 minutes with the oven off. Use a small flat-head screw driver and needle nose pliers to pull all the remaining silicone out of the headlight, you don't want any left at all, this could ruin the final product.
    S8: Give the main headlight circular reflector a good cleaning and fill the little area around the edge of the back piece with the silicone, make sure you fill the little "ditch" with a lot of silicone. Then push the clear lens back into the back piece making sure it is firming back in place and that all the clips are in place. Remove any excess silicone sealant with your finger. Once both headlights' sealant are completely dry go over the seals with a little more sealant to ensure that your headlights will not fog up down the road.
    i cant take the credit but i got this off another forum but i did it step by step and turned out good
  2. The Batman
    The Batman Rest In Piece
    cold hill ky
    :peace: cool!!
  3. jlyoung08
    im painting dylans right now...waiting on primer to dry
  4. cowboy
    cowboy Sheriff Staff Member
    nice
  5. The Batman
    cold hill ky
    cool man....i already got clears on mine i think...i may end up doin this too....
  6. TxFx04
    lol copyright from .... anyway i didn't think you were painting them for me lol i thought you were just giving them to me and i'd have to do the dirty work
  7. jlyoung08
    lol i wasnt sure so i figured id go ahead and do it...it cost 30bucks for paint primer sand paper and a 24pc tool kit since they didnt have any t10s jus out...ill paint 1 and you can do the other hahaha
  8. TxFx04
    lol well i suppose that works too. and the Hellas don't have the mounting brackets since i welded them to the lightbar so you'll have to fab some up :Grenade:
  9. jlyoung08
    haha damn i can do it though...i kinda wanna paint ur lights red lol
  10. TxFx04
    yeah just get some flat bar from home depot and bend it in a U shape and drill the 3 holes with a square bolt. ptm red ftl lol
