hp/torque mods
Discussion in 'V10 and Diesel Engine Performance' started by UtahFord, Apr 26, 2012.
  1. UtahFord
    Obviously there are the quick and easy three, exhaust, CAI, and chip/tuner what else is there for the diesel truck that doesn't cost a couple arms and a few legs
  2. TxFx04
    Injectors, upgraded fuel system. :shrug:
  3. ak_cowboy
    Nothing is going to be cheap. But you can upgrade your turbo or get twins :boobs:
  4. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    Upgrade your spool, egr delete, injectors, aux fuel filter, down pipe, better glow plugs etc.
    Sent from my iFord f150
  5. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    What motor do u have. You can get valve springs for about $90. If you have the 6.0 I would recommend bulletproofing it ex. head gasket, head studs etc. If you are adding power might as well run a better gasket and head studs. I'm gonna do mine when I get the money.
  6. yz85rider2002
    hes got a 7.3 if i remember right. more fuel and air are always good things. but if you do that, make sure you stud the motor
  7. UtahFord
    yup ive got the 7.3
  8. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    Valve Springs, 7.3L - Swamp's Diesel Performance
    7.3L Pushrods - Swamp's Diesel Performance
    Rollin Smoke Diesel. 1999-2003 Ford 7.3L Powerstroke ARP Head Stud Kit 250-4201
    200/30% Injectors (Hot Street) - Swamp's Diesel Performance
    Chip for Custom Injectors - Swamp's Diesel Performance
    ^ stuff I want
    I got those exact injectors and chip. Just the chip, inj., shift kit, and clutches make my **** fly. Mine has alot of torque it will spin these 40's easy
  9. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    If it doesn't get too cold there delete the back pressure valve I'm working on mine I just need a core plug
  10. UtahFord
    average of high 20`s in the winter usually, gonna be interesting this winter anyways its not a daily driver and it gets parked down the way from our apt.
