I Traded For This Today
Discussion in 'Member's Garage and Tools' started by davbell22602, Oct 22, 2012.
  1. davbell22602
    Bunker Hill, WV
    According to this I dont need shielding gas.
  2. Bdons-SD
    Yeah, you don't need shielding gas if you're welding flux core. It just spatters a lot. Most welders have an adapter for a tank so you can mig weld with shielding gas. It's cleaner and welds a nicer bead. I hardly use my tank since most of what I weld is out of eyesight, mostly trailers, machine buckets etc..
  3. AKBray907
    Flux welding also doesn't require nearly as much prep either. Basically it's like stick welding with a wire feed
  4. AKBray907
    Just remember that flux core you have to switch the posotive an negative leads
  5. davbell22602
    Bunker Hill, WV
    Where do I get adapter at?
    Please explain this detail. Never heard of this.
  6. mustangwarrior
    NE Ohio
    You're probably gonna want gas, i have a 110 HF welder an it wont wont run a bead for sh!t without gas, added a small bottle and it makes a world of difference
  7. The Batman
    The Batman Rest In Piece
    cold hill ky
    Please explain this detail. Never heard of this.[/QUOTE]
    :jester::jester::jester:
  8. Bdons-SD
    I don't know you're exact welder but there should be a fitting on the back that you can screw in a hose to attach a bottle. If not it may not be compatible, but the Lincoln's I looked at all had one, the one I got came with a bottle and everything. There should be instructions on switching from mig to flux on the inside of the panel.
    On another note, not to be a dick.. But if you weren't joking I would suggest a how to book on mig and flux welding.
  9. ak_cowboy
    Sweet trade!
  10. TxFx04
    if it doesn't have a fitting in the back for gas then it doesn't need it, but like brendon said there will be alot of spatter and porosity if you don't clean the area. I do fluxcore at work with gas and it throws down a really clean pretty bead.
    we also spray some anti-spatter on it to prevent it
