just bought a new truck
Discussion in '8th Generation and Older F-Series : 1991 - Older' started by 1998f150wes, Nov 22, 2011.
  1. mustangwarrior
    NE Ohio
    what year is it? if its an '80 or newer you could probly get a ttb front end and it should be a bolt in setup, or you could get a d44 solid from a '79 or older f150 and the coil springs are damn near bolt on, idk about your area but i've been having a hard time tracking down a d44 solid around here for a decent price, usually if they have one they want like $800 as is and that means its gonna nead to be rebuilt
  2. 1998f150wes
    1998f150wes CLASS OF 2013
    Guthrie, OK
    yeah every one wants way to much this f150 is a 89 and your saying if i go get a TTB front end itll bolt right up SWEET pull a part has them for 95bucks i want this thing to be a budget rig the most money im gonna spend is on a 351 with a light build and a 5 speed trans
  3. 1998f150wes
    Guthrie, OK
    well im gonna go get my new TTB frnt axle next week
  4. mustangwarrior
    NE Ohio
    yea assuming, and i believe the 2wd still has twin beams with coils and radius arms then it should bolt up, now dont 100% trust me on that
    what are using for a t-case?
  5. 1998f150wes
    Guthrie, OK
    yes it still does but im not sure on what i should do on a tcase i want to run a zf5 with a mild built 351w (bored .030 over stock bottom end with p/p heads intake and manifolds, and a little bigger cam)
  6. 1998f150wes
    Guthrie, OK
    what kind of MPGs are yall getting with a 351W Carbed
  7. mustangwarrior
    NE Ohio
    my 302 efi is only gettin 13.5 on a good day
  8. 1998f150wes
    Guthrie, OK
    alright better than i expected my 4.6 with 5"lift and 33" tires get 10.8 normal foot in gas mode and like 12mpg pussy footin under 2k RPM
