Leveling kit
Discussion in '13th Generation F-Series : 2015 - Present' started by SteadyEddie, Jul 6, 2016.
  1. SteadyEddie
    SteadyEddie Junior Member
    syr, ny
    Probably already a post I didn't see. Just picked up a '16 F150XL, loving it. Local mechs say not to do a leveling kit, screws with the boots and joints..... Of course they said that when I had the RAM too. What's the verdict... can I just level the front out?
  2. Bdons-SD
    As far as I know doing a coil spacer leveling kit doesn't mess with the angles THAT much. I guess it would depend what size leveling kit you go with.
  3. 2Canches
    2Canches Full Access Member
    Koots
    2" is fine.
  4. ak_cowboy
    Should be good with 2". Are you 2wd or 4wd?
  5. SteadyEddie
    syr, ny
    Thanks guys.... she's a 4x. Again, not looking for a full lift, just get rid of that Camaro looking droop in the front. 2" sounds good.....
  6. ak_cowboy
    Yeah, a 2" should be plenty. I'm not sure if Bilstein or anyone makes shocks for the 16s yet. You might be able to use some for the 15s tho
