New 1996 f250 owner
Discussion in 'Introduction' started by jdogali1989, Feb 3, 2017.
  1. jdogali1989
    jdogali1989 Junior Member
    US
    No real smoke. Only with the drive after running the truck after the heat soak. Was such a let down. Lol
    Sent from my SM-G955U using Tapatalk
    Dang it man.
    Figured it would have carbon
    on the rings, back side of the
    valves, combustion chamber
    and tops of the piston at least.
  3. jdogali1989
    US
    Hey, New update and some insight as the usual case.
    My truck is having a kick from 1st to 2nd gear. I found a E4OD transmission from a bronco with only 60,000 miles on it. Which i believe is a score. For the price of $150.00... My questions to you now. Is it a good deal? What should I do with this tranny before install... And how difficult is it to swap? Do I need to remove my transfer case to swap transmissions? Its my first time doing something like this. Cant afford a new transmission and figured this could be a win.
  4. Roush PSD Interceptor
    Not much help on trans knowledge.
    Sorry jdogali1989
    Couple other members can.
  5. thesman727
    thesman727 Full Access Member
    US
    That's a decent price. But before you do that, have you changed the Trans fluid and filter? That can be the cause of some rough shifting if the fluid needs to be swapped.
    And if you are just switching out transmissions, it's maybe a weekend project, one day if you have help. You'll want to drop the transfer case just for ease of access
  6. jdogali1989
    US
    I haven't changed th filter and the oil. I know on the stick it's pink. But perhaps I should change that filter
  7. jdogali1989
    US
    Another update. Found a clean bed for the truck.. amazing price of $150 I love deals. It's from a 1988 f150 looks like it was red then painted rattle can black. No rot. Just a hole in the bed. Looks like a lazy man fuel pump job. But I can weld a piece on metal in and call it a day.[​IMG]
  8. dchawk81
    dchawk81 Full Access Member
    You could cut a section of your current bed and match it up.
  9. dchawk81
    Yup take it behind the woodshed.
