New Review on Lund RX-Rivet Fender Flares for Ford trucks!
Discussion in 'CARiD.com' started by carid, Mar 28, 2018.
    Fender flares are a must have for any truck with big tires. The advantages of the fender flares are obvious – they keep road debris away from your truck's body, they make it look tougher and provide extra tire coverage. If you still have any doubts, whether or not your Ford needs this add-on, watch our new product review on Lund RX-Rivet Fender Flares and leave all doubts behind!
    Thanks to the rugged pocket grooves and exposed stainless steel rivets they help to prevent a paint damage from the flying debris and give your Ford an aggressive look you've always wanted. Easy to install with no drilling or cutting required, they mount to existing factory drilled holes attaching with clips and installing in minutes. Manufactured using Tri-Flex ABS thermoplastic material for maximum durability, these flares have a dense scratch-resistant surface and either smooth or textured black finish (also they can be custom painted).
    Features:
    - Made of tough and durable Tri-Flex™ ABS thermoplastic -
    - Extra wide design for larger tire and wheel packages -
    - Decorative 100% stainless steel hardware–rust-free -
    - UV-resistant to protect against fading -
    - Designed to fit each vehicle make and model -
    - Gives your truck or SUV improved protection against rocks and debris -
    - Available in a black smooth or black textured finish (paintable) -
    - Easy no-drill installation utilizing factory attachment locations.
    Lund Elite Series RX-Rivet Style Fender Flares at CARiD
    Still have any questions about Lund RX-Rivet Fender Flares? - Let me know in PM or in the comments below! ​
