No sway bars- need some information
Discussion in '9th Generation F-Series : 1992 - 1996' started by Masonsf150, Sep 25, 2013.
  1. ksingltn
    ksingltn Full Access Member
    Anniston, AL
    since your truck is a LWB 2wd, it didn't come with sway bars, at least i've never seen one that did. All of the SWB trucks had them, and it shouldn't matter if it's 2 or 4wd.
    Best bet is to go look for a 80-96 F-150 SWB std cab in the junkyard and pull all the pieces. The front bar and frame brackets you could also get off a bronco, but you need the axle beam brackets off a 2wd F-150.
  2. Masonsf150
    Masonsf150 Full Access Member
    St.louis
    Thanks for that information.
  3. Toplait
    Toplait Junior Member
    Clinton, Missouri
    Here is a picture of the Front Sway Bar I took them today...Although the truck has been lowered 5 inches in the front. I think I flipped some pieces upside down to make it fit..
  4. ak_cowboy
    Thats a sweet looking truck. You should start up a build thread for it!
  5. Masonsf150
    St.louis
    Did yours have holes for the sway bar mounts? I don't see any on mine. How much did the junkyard charge you for the entire setup
  6. Toplait
    Clinton, Missouri
    The sway bar came stock on my 1992. We bought it new with 4 miles on the odometer. It's been a project ever since... The front sway bar is stock. I replaced the rear sway bar with a thicker sway bar from Hellwig if I remember correctly about 12 years ago.
    There should be a skid plate that bolts to the frame with 4 bolts. Located behind the front bumper...Then there is 4 holes in the skid plate for the front sway bar bushings.
  7. Darth Bama
    Use some 1st gen Lightning sway bars
