Post up pics of your Intake I ran Gotts+K&N for a while, then switched to this JLT. I've noticed drone at 3000rpm and more intake noise. Downside is more susceptible to mud/water when offroading.
I've been running an AirAid CAI for 6 years now and it's never given one problem. Still using same filter that I clean every 30K. Well spent 205.00 IMO.
Ive got the gotts mod but now im lookin into finding some 3in black pipe... Ive check several lowes and HDs and no one has the 3in stuff.. And boom goes the dynamite.
I built my own. Drawing air through 3 seperate 4" ducts located outside the engine bay. Does it work as a CAI? See below
i'm running a k&n, only because i got it at summit scratch and dent for $70, definitly more sound out of it, plan on building a box like twinskrewd did
Well from the runs I did with my aFE before I temporarily had to take it off, with my truck back to stock there is a noticeable difference. Love it and can't wait to get it back on. Sent from my iSmarty 4
Best CAI I've seen What was the ambient temp in that last pic? My JLT runs about 10* warmer than outside going down the road.
Here's how the heat soak test I performed. Drove the truck for a total of 14 miles. First 10 were city the last 4 were highway. Pulled in the driveway and never shut her down. I grabbed my two hygrometers and placed them on the tailgate of my Dads Ranger parked in front of my truck for four minutes to obtain an accurate outside temp. Then I popped the hood and set them in place. One lying on top of the MAF as close to the box as possible and the other inside the box. I closed the hood and let her idle for 12 mins to get a worst case heat soak then popped the hood removed the airbox cover and the results were awesome. 51 degrees different. If I were to insulate the box and put a gasket on the lid it would probably be even better.
