Pictures of old brakes
Discussion in 'Exterior' started by davbell22602, Sep 13, 2011.
  1. davbell22602
    Bunker Hill, WV
    Here's pics of the old brake drums and brakes when I pulled the drum on the front passenger side. 67 F100 2wd
  2. TxFx04
    they look pretty good, just replace those bearings and grease them good
  3. davbell22602
    Bunker Hill, WV
    Your joking right? I saw torn dust boot on the wheel cylinder. Plus I already bought new shoes, hardware, and wheel cylinders for the front drums.
  4. TxFx04
    well i guess its different in person.
  5. supercrewzn
    They didnt look too bad to me either Dylan. All I see is some surface rust....
    The pads still have the numbers on them...
  6. davbell22602
    Bunker Hill, WV
    The primary shoe is more than half worn on this duo servo brake system.
  7. rrogers
    maybe its just the pics but i have seen worse.
  8. supercrewzn
    Same here ricky. I just changed pads and rotors on a car that was metal to metal.
  9. cowboy
    I've seen worse as well, my rear pads came away from the metal before. I normally replace the entire hardware every 2 brake changes when doing drums.
  10. Roush PSD Interceptor
    If anyone has driven a vehicle with front drum brakes, they leave a lot to be desired in braking ability. I don't blame you for wanting new shoes on those front drums.
    David I may be wrong, but isn't there supposed to be a metal bar (drawn in white) that goes between the red arrows I drew on the pic with flat circular springs (blue on drawing) on each end? I call it a "load spreader".
    Pardon my crude drawing.
