Possibly trashed U joints?
Discussion in 'Lifted' started by TxFx04, Jun 18, 2013.
  1. TxFx04
    You free Saturday? :jester: was gonna drive up there anyway to check out that job :shrug:
  2. 4ctNduction
    T-E-X-A-S
    if you had a supercharger this wouldnt have happened.....get on that STAT !
  3. VanoFord
    possibly. i know i'll be around the house doing stuff to get it ready for sale next month. depends if i'm free/in between projects but just shoot me a text. i'd verify from a local shop that you do have the replaceable Joints and not needing a complete shaft. if so, get the u-joints from Napa, not Vatozone.
  4. TxFx04
  5. Big'un
    them ujoints come out i know , cuz i put new ujoints in my screw when i put my rcx on
  6. TxFx04
    you just grind down those stakes and press them out?
  7. Roush PSD Interceptor
    Grinding down stakes makes hamburger.
    :jester:
  8. TxFx04
  9. VanoFord
    all you do is remove the c-clips, then pop them out, since the cap is broke on one already, it wont be too hard to get out. get some 60grit and give the inside of the yokes a light scrape and the new one will slip right in.
  10. AKBray907
    It's staked though, so he'll have to cut the center section of the u joint out, push/press the bearing caps into the center to remove and then file and sand te stakes flush. Install new joint with with clips
