PSOM trouble
Discussion in 'Engine & Performance' started by Patricia, Jun 23, 2017.
Is a visual exam of the tone ring accurate?
  1. PSOM units are unreliable
    0 vote(s)
    0.0%
  2. Faulty wiring
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Patricia
    Patricia Junior Member
    Orlando
    Two months ago the speedometer in my 1992 f150 started fluctuating, and then flatlined. Truck started shifting hard at same time. I took the advice I found in the forums and switched out the speed sensor on the rear axle and bought a used PSOM online. The PSOM was fried, so I ordered another. Odometer and speedometer worked with 2nd replacement and shifting was smooth again - but the speedometer still fluctuated 20 MPH up and down when going over 45.
    Time to get a pro to help. Took my baby to top electrical mechanic in Orlando. Mechanic flushed and serviced rear axle, checked tone ring and said it was in good shape. He ran diagnostics, traced each line from cluster to axle, and said the PSOM was faulty. OK... seems a bit odd, but I ordered another. Another week goes by and mechanic says the third replacement PSOM is bad. I am assured that the diagnostics are accurate and there could be no other problem. He says I might have to buy several more to get a good unit. Seriously?
    I have now ordered three more PSOM units - to make sure!
    Any suggestions out there?
    Welcome to fordfullsize.com
    Patricia.
    Someone here should have an input to your question,
    It may take a day or so for
    that member to see and
    Read your question.
