pulled codes...
Discussion in 'Engine & Performance' started by mustangwarrior, Jan 20, 2012.
  1. mustangwarrior
    NE Ohio
    the heater circuit for all three o2 sensors popped up, don't know why, they are all brand new and and the fuses are good
    the other two were for banks 1 and 2 were lean, would that then lead to my suspicion that an injector(s) are either bad or really clogged up?
    If its not reading the right A/F mixture from the O2 sensors, it might be pulling fuel and causing you to run lean... How long ago do you have them installed?
    How many miles are on your injectors?
  3. mustangwarrior
    NE Ohio
    the injectors are original so around 142k and the o2's were just installed this summer with probably less than 1k on them
  4. ak_cowboy
    I'd look at replacing the injectors then :jester:
  5. WoodenNickle
    WoodenNickle Junior Member
    NE Ohio
    Are you still having trouble with the O2 sensor heater circuit?
