Rear bearing failure axle tore up
Discussion in 'F-250 and F-350 Wheels and Tires' started by dhide371, Jul 28, 2016.
  1. dhide371
    dhide371 Junior Member
    New Jersey
    My hub completely destroyed my axle spindle. What are my options. The new hub and bearings sit perfect however the seal surface is FUBAR. Image1469704796.361696.jpg
    Welcome to fordfullsize.com
    I don't have rear drum brakes.
    Dress it with an ultra fine wire brush then progressive finer and finer
    wet dry sandpaper and run an over size seal ?
  3. dhide371
    New Jersey
    Thanks for the response! Those are actually our parking brakes inside the disk. I think that's what I am going to do. Also the manual doesn't call for sealant on either side of the new seal. However when removing the old there was sealant inside the hub and seal. I'm wording of I could do the same on the axle as the seal is 2 parts and spins within itself. I can't see any other solution other then replacing the axle. This is what I get for buying a pretty truck. Guy must have never changed the gad damn differential oil. It was brown when I drained it . Replacing all the bearings in pumpkin as well I guess
  4. Roush PSD Interceptor
    Now ya have me wondering about mine.
    Changed the diff oil fanatically but have missed
    changing the parking brake shoes in a timely manner.
  5. dhide371
    New Jersey
  6. Roush PSD Interceptor
    I'm curious, how many miles on your F250/F350?
    @dhide371
  7. dhide371
    New Jersey
    227.000 :) starts right up no smoke and runs hard!
  8. Roush PSD Interceptor
    165, xxx here.
  9. dhide371
    New Jersey
    So after a half hour of panic and thinking somehow my axle grew some new steel. I found that my race was still on the axle from the inner bearing.... Look how gone it was!!! [​IMG]
  10. dhide371
    New Jersey
