Remod thread for big blue
Discussion in 'General Discussions' started by thesman727, Jun 4, 2015.
  1. thesman727
    thesman727 Full Access Member
    US
    Fixed one of my oil leaks today. Pulled the valve cover gasket off to discover it in 2 pieces...exciting. Anyway since the cover was off anyway I figured I might as well paint it so I grabbed some duplicolor ford blue and sprayed it on. Looks a whole lot better now. Think I'm gonna paint the upper intake at some point but I dunno right now
    Aaaand I forgot to take a picture so I'll do that tomorrow
    Killed two birds with one stone.
    Upkeep and upgrade on appearances.
    thesman727 likes this.
  3. thesman727
    US
  4. thesman727
    US
    Hooray for electrical problems. Last night it cranked over once and then wouldn't start...then today I throw in a new starter and still nothing. Waiting for a ride right now to get a new solenoid, hopefully that's the issue. Other than that I don't really know what it could be. All connections appear good, grounds are solid
  5. Roush PSD Interceptor
    Bypass the solenoid with pliers to test.
    Could be crank wire from ignition switch.
    Use test light on small wire that's on side of solenoid when cranking.
    The ignition switch may have security torx screws.
  6. thesman727
    US
    I found the problem. Replaced the starter, solenoid, ignition switch, and finally figured out that it was the clutch rod switch
  7. Roush PSD Interceptor
    Your starting circuit is good to go now.
