Someone cut the wires to connector going to the key switch and I need to solder the connector back on the harness. Does anybody know specs for a the wiring harness on a 67 F100 2wd base model 8ft bed? Amps, watts, etc? I know its 12 volts.
http://www.painlesswiring.com/Manuals/10117.pdf This is installation manual for a painless harness but has many pictures and diagrams of the circuits on 67-77 F100's. Pages 41-45 have all the circuits, wire colors, wire gauge size and point to point connection needed for each circuit listed. Look at page 37 for the pin out of an ignition switch on a 1967 F100. Fuse requirements for each circuit page 40: Wipers 15 Radio 10 Coil 30 Heat/AC 30 Gauge/Choke 10 Acc.Relay/4x4 20 Turn/Back up 15 Radio/Clock 10 Horn/Cigar 20 Stop/Cargo 15 Headlights 30 Dome/Hazard 15
