seat belt codes
Discussion in '11th Generation F Series : 2004 - 2008' started by Zee944, Apr 4, 2018.
  1. Zee944
    Zee944 Junior Member
    Albuquerque NM
    I keep getting a 33 seat belt code and I'm not sure how to go about fixing this.. from my understanding the way you read the seat belt code error you count how many times the first flash is and then there's a pause and then count how many times the second set of flashes is.. example the first set of flashes if it flashes 4× the first number would be 4 then there is a pause the second set of flashes if it flashes seven X then the second number would be 7..like AutoZone, O'Reilly's know how to go about fixing this if anyone has experienced this or knows about code 33 I could use your help any info or feedback would really be appreciated thank you..
    What type of vehicle are you working on Zee ?
    I'm taking a wild guess it's a Mercury Gran Marquis
    and it's either the seat belt buckle driver and/or passenger spring or the entire driver's side seat belt and retract @ $750 dealer repair cost.
    Of course these parts can be obtained at a parts salvage yard much cheaper especially if you pull them and do the remove and replace on the vehicle.
    Was I correct ?
    Zee944 likes this.
  3. Zee944
    Albuquerque NM
  4. Zee944
    Albuquerque NM
    Actually it's my own truck lol..2005 F150 Fx4 ..about 2 yrs ago the down the street rammed in to the truck Ford dealership put a new bed on there and fixed everything shortly after that I started getting seat belt code error
  5. Roush PSD Interceptor
    12=Low Battery Voltage
    13=Air Bag Circuit Shorted to Ground
    14=Primary Crash Sensor Circuit Shorted to Ground
    21=Safing Sensor Not Mounted to Vehicle Properly
    22=Safing Sensor Output Shorted to Battery Voltage
    23=Safing Sensor Circuit Input Feed/Return Circuit Open
    24=Safing Sensor Output Feed/Return Circuit Open
    32=Driver Side Air Bag Circuit High Resistance or Open
    33=Passenger Side Air Bag Circuit High Resistance or Open
    34=Driver Side Air Bag Circuit Low Resistance or Shorted
    35=Passenger Side Air Bag Circuit Low Resistance or Shorted
    41=RH Primary Crash Sensor Feed/Return Circuit Open
    42=LH Primary Crash Sensor Feed/Return Circuit Open
    44=RH Primary Crash Sensor Not Mounted to Vehicle Properly
    45=LH Primary Crash Sensor Not Mounted to Vehicle Properly
    51=Air Bag Diagnostic Monitor Internal Thermal FuseFuse Blown Due to Intermittent Short to Ground
    52=Backup Power SupplyVoltage Boost Fault
    53=Primary Crash Sensor Circuits Resistance to Ground or Air Bag Diagnostic Fault
    I would try the reseating of the connection ONLY AFTER disconnecting the battery,
    and or fuse circuit for the air bag.
    Use some di-electric grease in the metal contacts of the terminals
    and reseat the connection. Easy to find the wiring harness is yellow.
  6. scoopyg
    scoopyg Junior Member
    florida
    Are these seat belt issues life-threatening? My dealer (the one who wanted to charge $182 labor to swap out a PCV hose) told me I have some seat belt codes. But the seat belts seem to be working just fine. Occasionally the reel on the driver's side gets sticky, but it resolves itself and it's OK.
  7. Roush PSD Interceptor
    Seems very expensive labor for a PCV hose.
    If the belt latches and you can tug on it firmly, as in a quick strong motion, it should hold up in a crash.
    As far as the codes, depends on what specific code.
    Something like sensor A B open or not detected could be as simple as reconnecting the plug.
    Others I believe can detect passenger belt engagement and set off the dash, side curtain and seat belt air bag just from that sensor depending on the model of truck or vehicle the owner has and if it is equipped with those features.
