Small vibration when changing to a lower gear..
Discussion in '11th Generation F Series : 2004 - 2008' started by Troovdaddy17, May 1, 2013.
  1. Troovdaddy17
    Troovdaddy17 Junior Member
    BC, Canada
    Hello fellow f150 owners.. I have a 2007 fx4 with 113k kilometers on it. The problem I am having is usually when I am going up a hill at 80-90km/h and my truck will downshift to stay at speed. When it down shifts there is a brief vibration as it changes gears. I'm not sure if this is a serious problem or not but if anyone could give me some input that would be much appreciated!
  2. Troovdaddy17
    BC, Canada
    Oh also it doesn't happen all the time just the odd time..
  3. ak_cowboy
    Check your transmission fluid. Try running with overdrive off also. if that stops it, then your torque converter is going out.
    sent from my igloo
  4. n-3-s-l-0
    n-3-s-l-0 Full Access Member
    Rogers, MN
    My truck did the same thing, it is the torque converter chattering.
    Its a common problem with Ford Transmissions.
    Oreilly's has an additive called Dr. Tranny Instant Shudder Fix, I put it in my tranny and ever since it has been fine.
