Tailights went out
Discussion in 'General Discussion' started by stx.dead.I, Jan 26, 2015.
  1. stx.dead.I
    stx.dead.I Member
    I got a 2010 f150 platinum. I tried to do led bulbs in the tailights housings and used resistors. When I installed the resistors the tailights would not turn on woth the headlights (night driving) I swapped back to halogen bulbs and now the problem persists. They will 9nly turn on with brakes turn signals or briefly when I use my remote to unlock the vehicle. Does anyone know what my problem maybe I am thinking about reconnecting my battery to see if that will reset it.
  2. AKBray907
    take the resistors out
  3. stx.dead.I
    stx.dead.I Member
    I removed them when I swapped out the leds back to halogens
  4. Roush PSD Interceptor
    Problem isn't in the wiring if they will come on with
    remote to lock unlock doors but not with
    headlight switch.
    Check the fuse panel for a blown fuse on the
    parking light circuit.
    Test the parking light wire at the headlight switch.
    x2 on the fuse. I had the same thing happen with the Jeep. Installed LED bulbs, running lights worked, test brakes, bulbs didn't work. Blew the fuse.
  6. stx.dead.I
    stx.dead.I Member
    Anyone know which fuse that would be or a diagram??
  7. Darth Bama
    There should be a diagram in your manual. It's not super detailed, but it will let you know what the fuses are for.
  8. stx.dead.I
    stx.dead.I Member
    Got them working after swapping out the 15A fuse @NUMBER 22SLOT. Thanks for the help!
  9. ak_cowboy
    Great! :cheers2:
