TunaSlayer Mod Progress
Discussion in 'General Discussions' started by TunaSlayer, Jan 16, 2011.
  1. TunaSlayer
    TunaSlayer Full Access Member
    Martha's Vineyard
    Ok rather than rewrite all this crap, here's the link to my build thread from F150forum if anyone's ever interested in anything
    http://www.f150forum.com/f4/tunaslayer-mod-progress-lots-pics-71119/
    Heres the truck at the dealership the day I bought her. 19k miles, one owner.
    And now it sits like this
    I converted my Hella lights to 5000k HIDs to match the headlights and fogs. It's like the apocalypse at night now.
    Most recent mod was the AAL, which I needed after the level since it's my work truck and I haul at lot of weight. The rear wasn't exactly sagging, but it did sit a little lower in my eyes when loaded.
    And here's the rod rack I made out of mahogany. I carry a lot of expensive tuna rods and was sick of them banging around in the bed when transporting them.
  2. westtnfx4
    Looks great dood :cheers:
  3. cowboy
    ^x2 :waytogo:
  4. yz85rider2002
    ^x3
    ^x4
    Sweeet truck
  6. TunaSlayer
    Martha's Vineyard
    Thanks guys. Here's the step by step break down of the mods so far.
    First things first, Lightning style exhaust: Flowmaster 40 w/2 side exit tips 3.5"s. The fender flares were already faded as well, so 4 coats of jet black paint fixed that. Also tinted the front windows 20%
    I have a Mustang with a Panasonic Strada and love it. Had to put it in the truck
    Next I wanted to tint the tail lights and 3rd brake light. I took pics of the process for the 3rd brake light...the tails are the same process.
    First I wetsanded the bare brake light with 1000 grit.
    After wiping it down with Sem Solve paint prep, I sprayed the first coat of VHT Nightshades
    2nd coat
    Wetsanded with 1000 grit then 2000 grit
    After wiping down again with Sem Solve, first coat of clear. I have a gravity-fed paint gun and 15 gal Dewalt Air Compressor.
    Wetsanded with 2000 grit again then 2nd coat of clear. When fully dried, color sanded
    The end result. I also used a heat gun and pealed off the stock FX4 decal and replaced it with a flat black 2010 FX4 decal
    The chrome running boards and F150 emblems weren't helping the black out, so those were painted black rather than replaced with aftermarket ones (I like the factory ones best)
  7. TunaSlayer
    Martha's Vineyard
    I'm a commercial fisherman and wanted a better way to transport a lot of my reels to and from the boat when tuna fishing. I had seen a lot of rod racks for the bed but nothing that went with my taste. Decided to design and build my own. I build custom furniture as a hobby so I love working with wood. I'm not much of a quality welder so woods the way I went. Started out with mahogany 15ft 2x8 mahogany in the rough, cut down to size, put through the planer and squared off. Figured out the measurements and even placement of each rod holder and started on the drill press
    All finished with the rod holder holes, all eleven
    Designed it to mount using the predrilled holes in the sides of our beds that are accessable through the bed rail caps. Attached the sides of the rod rack with 4 lag bolts and wood glue and marked the 33 holes that were needed to be drilled for the rod holders
    2 Coats of wood primer then 4 coats of Satin black outdoor paint then rod holders mounted.
    Mounted in the bed. Around this time I also had the bed Line-Xed. I haul a 22ft trailer with lobster traps and also stack them in the bed, so needless to say it was VERY scraped up. Didn't want any bare metal to start rusting through.
  8. TunaSlayer
    Martha's Vineyard
    Next mod was the 2" leveling kit from Autospring
    Before
    After
  9. TunaSlayer
    Martha's Vineyard
    The running boards I had painted black with getting a few chips here and there from rocks (half the roads I drive on here on the island are dirt and rock). I had planned on going off-island the the shop the Line-Xed my bed but couldn't find the time (45 min, $77 ferry ride then 2 hour drive to North of Boston), so I bought some Dupli-Color Spray On Bed Liner. It came out better than I thought and is more resilient than I thought it would be.
    Did the mounting brackets as well.
    Got ambitious and did the trailer hitch too
  10. yz85rider2002
    one of the trucks as to why i want to get a light bar
