Fan Shroud Mod to Improve Access:
Discussion in 'Tech Info' started by kattumaram, Dec 5, 2010.
  1. kattumaram
    kattumaram Member
    Edgewater, Florida
    :cool: I have this mod posted on another forum, but I thought a repeat of the information here would be of benefit:
    The series of pictures tells it all.
    The materials are: 1-24" length of 1/8"x 1-1/2" aluminum bar stock. 10-pop rivets. 10- 6-32 x 3/8" #2 Philips pan-head screws. 10-aluminum washers to go between pop rivets and shroud. 10-fiber washers to go between screw heads and shroud.
    The shroud is cut using a 24 tooth hacksaw blade mounted in a single-blade handle. The cuts are started at the outside edge and continued to the rim, but the rim is not cut through until the brackets are installed in order to maintain alignment of the shroud pieces.
    The brackets are twisted end-to-end so they lie flat on the shroud, drilled to clear the pop rivets and tapped for the 6-32 screws.
  2. kattumaram
    kattumaram Member
    Edgewater, Florida
    Shroud Mod Continued:
    Shroud mod pics:
    The top section of the shroud is easily removed by removing the ten screws. The bottom section comes
    right out if need be after removing the two mounting bolts. Ease of access to the front of the engine is vastly improved.
  3. Darth Bama
    Nice write up! Welcome aboard as well!
  4. ak_cowboy
    Nice writeup. Thanks for coming over!
  5. westtnfx4
    Thanks Kat....good to see you made it over!
