You should look at the new mickey thompson Baja Claws TTC they look real good .more spaced out than the old ones and have the same sidewall design as the goodyear MTR's
Toyo's are the best overall. I know cause I owned a set. They don't wear fast (don't listen to bigun his tires still look brand new,he loves yanking peoples chains) they are quite and work well off road. The MTZ is also a great tire. They are long lasting and look good to. The price is the same between them and the toyo's. So it really just comes down to what you want. I personally would go with the Toyos if you had the money to spend.
Listen nn your tires look brand new I was just there last week and studied them so unless you have been doing burnouts (I know you haven't cause that truck wont spin the tires in slick mud) then they are still the same
