Idle Issue.....
Discussion in 'Engine & Performance' started by The Batman, Apr 23, 2011.
  1. The Batman
    The Batman Rest In Piece
    cold hill ky
    ok...so the nite has been dong this thing for a while now and i have put off the issue for quite somtime...but when she gets warmed up she will drop rpms and oil pressure and somtimes die...it will start right back uo with no issue....it happens when i pop it in nuetral after a getting off the interstate or driving for a good distance...i just cant figure what it is...any idea's guys?:hmm:
  2. The Batman
    cold hill ky
    no idea's?
  3. Roush PSD Interceptor
    Iac
  4. The Batman
    cold hill ky
    and that is?
  5. westtnfx4
    Idle air control.
    You need to tell everyone what setup you have. Carb? EFI?
  6. iowaredneck
    ^x2
  7. The Batman
    cold hill ky
    efi
  8. westtnfx4
    Then it's prolly the IAC valve.
  9. The Batman
    cold hill ky
    now the next ???...where is it located and can it be replaced and about how much...
  10. The Batman
    cold hill ky
    ok...scratch that last...found it...$70!!! omg!....damn truck...everything for it seems to be around a hundred bucks...lmao!
    well i unplugged it and started it up and it died..then i plugged it back up and it idled really high for a minit and then it throttled down and died...and that was after it had sit for a while..so thats definatly it...dammit...thanx doods
