Got stuck in 3 feet of mud
Discussion in 'Member's Truck Photos' started by Sl33p3r, Apr 27, 2011.
  1. rrogers
    Huh?
  2. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    Someone that wants to make it thru. I have a 2wd if you can beat what I did in my truck come on down I'll put my title on the line that you can't get thru goin slow.
  3. rrogers
    you are a real bad ass man
  4. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    I know how to mud I've had a few street legal mud trucks. And when I had a 2wd s10 I went thru a lot of mud at 40 + mph. I experimented 2wd Mudding with a 2wd s10. I tried different amounts of weight, different gears, and speeds. I found going faster in a 2wd without super aggressive mud tires and a lot of hp makes you go further in the big boy pits. I went thru a pit with 44 inch ruts going 50 and made it thru with no damage. The only time you will damage your truck doing this is if You hit a stump or rock.
  5. rrogers
    You have lived and learned a lot in your 18 years
  6. supercrewzn
    You wont see me in a mudhole. Im not dumb enough to tear a perfectly goos truck up. Next thread will be Help I broke my truck ...
  7. rrogers
    I dare you to make as far as he did you could do seventy and glide right across
  8. TFIDDLE
    I had a friend who hit one fast in a ranger. The result was a blown motor.
  9. rrogers
    Hitting one at forty mph would cause a lot of damage in a stock 2wd
  10. TxFx04
    oh... i've done some dumb things offroading and mudding..hell i even got hit by a yota and still have the scars on ol white but i would never go faster than 20 mph in the mud. I don't know how you didn't break something going 50 i guess you just got lucky. if you have to go faster than 20 mph then you probably shouldn't be mudding in that area, especially in a 2wd with an open diff. You need to know your limits
