Passenger airbag deployment
Discussion in 'General Discussions' started by ak_cowboy, May 11, 2011.
  1. ak_cowboy
    Does the airbag deploy through the top panel (bouncing off the windshield) or straight out of the front panel? (The one facing the seat)
    Got an idea I'm working on...
    Sent from my Igloo
  2. Ak 08 stx
    Ak 08 stx The Only One
    North Pole, ALASKA
    i beleive it flips or comes straight out i am not very sure about this though
  3. 01f1502wd
    ^ya comes out straight to your face! :jester: :jester:
    in mine it pops up...i know cuz i was trying to paint the panel and it wasnt popping off....found out you have to unbolt the airbag (which that panel is attached to the front) and all of the tabs on the bottom broke the top ones didnt so i would say the top ones are gonna stay.
  4. ak_cowboy
    ^ ok, so you're saying it comes out the top panel, then ricochets off the windsheild, and saves your life. Thats what I thought happens, but couldn't find anything definitive.
    what I'm thinking about is the panel that faces you doesn't have anything behind it, and is pretty large.... So you could probably fit a monitor in it!
    fwiw, I had this thought before seeing this truck with it...
  5. Darth Bama
    I'd make sure, I'm thinking that whole piece has something to do with the bags deployment. Any custom work I've seen done to the dash area has required the owner to permanently disable or remove the passenger side airbag.
  6. rrogers
    Imo it seems it would come out the front panel and I think you access it from the top to remove it
  7. ak_cowboy
    Yeah, its attached to the top panel, cuz it came out when I painted my interior... I don't want to mess with it right now, cuz I still have the stock front end. If I upgrade to a ranchhand or something later I might feel more comfortable disabling it.
  8. rrogers
    Cool
