Wipers?
Discussion in 'F-250 and F-350 General Tech and Info' started by rrogers, May 30, 2011.
  1. rrogers
    Today i hit a speed bump and my wipers turned on and would not go off. i pulled the fuse(thanks to assistance from abe finding it),but would like to see what yall thought the problem is.
  2. jlyoung08
    thats weird
  3. rrogers
    very weird they wont turn off unless i pull the fuse
  4. ex4banger83
    :hmm:
  5. 01f1502wd
    hmmmmmm you hit a bump and they came on...what if you were to hit another bump would they turn off? :hmm:
  6. Darth Bama
    Damn, that's wild I've never heard of anything like that before. Possible wiper assembly went bad??? :think:
  7. westtnfx4
    It's got to be in the the switch inside the steering colum I bet....
  8. Bdons-SD
    Theres all kinds of switches and contacts inside the switch assembly. Could just be a bad or dirty contact. 2 screws and 2 plugs to pull it off the column, and 4 torx screws to pop the assembly apart. gotta pull the ignition lock cylinder to take the column trim apart, kind of a pain, gotta be careful no to break the "pinger" contact clip/ unless you dont want a door pinger anymore. i taped mine off.
  9. rrogers
    thanks guys im gonna look in to it and see what i can come up with. jarrett i hit another bump and sometimes they would go off but come right back on.oh well its not raining today. i looked really retarded riding around hollering at hos with my wipers on.
  10. westtnfx4
    :jester:
