exhaust questions
Discussion in 'Engine & Performance' started by schrambo, Jul 1, 2011.
  1. schrambo
    schrambo Member
    Fond du Lac
    i have a 1997 f150 with the 5.4L
    right now im running stock manifolds to all stock cats (four cats)and aftermarket o2 sensors to a single camber muffler out the rear. if i took out my rear cats and ran maganaflow cats for the front cats would i throw a check engine code
    so all i want to do is simple remove the back two cats and replace the front two with high flow cats will i set off a code?
  2. c418
    c418 Full Access Member
    in theory you shouldn't get a code. it'll be a loud mofo.
  3. Auburnfan400
    Hartselle, Alabama
    so...you wanna replace the 4 stock cats, with 2 magnaflow hi-flows? You shouldn't run a code. And if you do there's ways to fix it. And yea, its gonna be loud :peace:
  4. ex4banger83
  5. iowaredneck
  6. ex4banger83
    :chewie:
  7. ranger
    ranger Full Access Member
    Fond du Lac
    you will prolly throw a code i do with just my rear cats deleted
  8. schrambo
    schrambo Member
    Fond du Lac
    well we will see boys im going to get my new down pipe from a buddy today and then im ordering my new cats this weekend and put it on the day all the cats get here ill post pics
  9. THEPRODJECT01
    THEPRODJECT01 MARKK
    odum , ga
    i have all my catts out, and mine isnt throwing a code, ive had this set up for almost a year
