Overheating, stumped
Discussion in 'Engine & Performance' started by Nitewolf, Jul 2, 2011.
  1. iowaredneck
    you are probably right thomas. water pump probably
  2. supercrewzn
    My efans only run when the truck has been sitting at idle or if the ac is on. They don't have a need to run if I'm going down the road.
  3. Roush PSD Interceptor
    what does an antifreeze/coolant tester measure the glycol concentration at?
    Maybe a flaky temp sensor?
  4. Nitewolf
    Nitewolf The Big Bad Wolf
    Clarksville, TN
    dunno ill just have the shop look
    Sent from my DROID2 using Tapatalk
  5. Big'un
    Oh yes it wud, blowcaine did
  6. Thumper4x4
    Thumper4x4 Full Access Member
    Arizona
    204 isnt overheating my truck runs between 196 and 208 all day
    my guess a faulty sensor
  7. Nitewolf
    Clarksville, TN
    Maybe it is just a sensor cause it's never shown me as overheating before.. could I be running hot cause it's mid 90's outside and i'm running max a/c all the time?
  8. westtnfx4
    My guess is the fan clutch first. Next would be a faulty sending unit. (what runs the temp gauge)
    If a overheating indication occurs, ck the coolant level in the system. Make sure the wiring between the gauge and the sending unit is secure and all fuses are intact.
    To test the temperature sender, check that it reads in the cold range when the engine is cold. Disconnect the electrical connector from the sender and attach a jumper wire between the two pins of the connector. With the key ON, the gauge should now swing to full hot. If it doesn’t, the problem is in the circuit from the sender to the instrument panel. If the gauge does swing to full hot when testing, but doesn’t when the connector is in place and the engine is hot, replace the coolant temp sending unit.
  9. Big'un
    if the guage shows its hot , and its not pukin out then its not hot
  10. Nitewolf
    Clarksville, TN
    Well I tried to look up normal operating temp for my motor but I can't find it
