Rough/Bad Idle
Discussion in 'Engine & Performance' started by SolidF150, Jul 18, 2011.
  1. SolidF150
    SolidF150 Full Access Member
    When driving yesterday felt rough idle out of nowhere and vibration at stop light. Only happens when not accelerating...
    Fuel pump is out of question replaced less then year ago
    Changed fuel filter, checked all fluids and ran through carb an injector cleaner through gas
    Tomorrow I will be checking the PVC valve and hose for any holes since....
    Any other ideas an fixes that could cause this??
    Thanks!
  2. KingRanchDiesel
    Mobile, AL
    hmm theres been some other threads about the same problem if u wanna check them out just search for "rough idle" or whatever. i think the guys have listed some of the most likely causes of that in there! hope you get it fixed
  3. SolidF150
    Thanks! After running the DTC's getting Lean flow on passenger and driver... opened the hood and found my pvc elbow completly split in half.. looks like the common problem just like the fuel pump was the answer again..
  4. KingRanchDiesel
    Mobile, AL
    o wow hah. im glad you fixed it
  5. liter of cola
    liter of cola X tra L arge
    INDIANA
    :jester:
  6. SolidF150
    Yes, also good thing it was a 5 dollar fix.. No autostore carries an elbow for the 98 and up. Ford wanted 75 bucks for the whole vacuum system. Just went to local auto store and bought hose to fit.
    Pics are in my album, if over 80,000 miles would doubt check your elbow.
  7. SolidF150
    Bad Elbow
    New 5 dollar Fix
  8. liter of cola
    INDIANA
    that would do it!
  9. KingRanchDiesel
    Mobile, AL
    dang that thing was torn apart
