Billet Grille!
Discussion in 'General Discussions' started by TFIDDLE, Jul 23, 2011.
  1. TFIDDLE
    Dang that suks. So with that billet u dont have to cut anything?
  2. Darth Bama
    Mines a bolt over, no cutting
  3. TFIDDLE
    its only 40 bucks??
  4. Darth Bama
    Not sure what the bolt overs cost nowadays. I paid $150 back in 2003. I'm sure they've got cheaper. There's not a whole lot to installing the regular billet grilles. If you can score one for less then $50 I'd suggest just going that route over a bolt over.
  5. iFX4
    iFX4 Chief
    Florida
    heres the thing bro.....especially if you want to get rid of the emblem....you just need to save up if need be and get a replacement grill. if you get a overlay....you will be able to see the honeycomb through it and if you take off the emblem then you will see a big plastic oval behind the grill....
  6. supercrewzn
    Listen Tyler. The honeycomb will cone out of your grille so no cutting. Then the billet bolts in it's place. Don't do an overlay.
  7. TFIDDLE
    Okay sounds good, how much is that thomas?
  8. Raevsky97
    Raevsky97 bagged 97 f150
    Derby, Kansas
    thats why i was saying get the 150 is one cuz some grills done unbolt the center alone from the shell and some do and u can always see the old grill under the bolt over
  9. supercrewzn
    His will unbolt and there about 40 bux off ebay
  10. 97madness
